I’m trying to add a background map in my Yarbo Android app. I choose to use google maps, it perfectly shows my yard, but I fail to understand how to align it with the mapped area.
Tried 100 times with moving, zooming etc, but there is nothing to align it to. And when I click OK to continue, the google maps image is tiny piece somewhere God knows where and not aligned at all.
You have to line up the areas with the image manually. You have to drag the image over the areas. The areas should overlap the background picture helping you to resize and align.
Microadjustment of uploaded (probably also for sat) image will make things simpler.
I uploaded image from dji drone and trying to adjust it perfectly for second month time to time. But its too difficult to merge it with the map as you cant micro adjust, zoom in, move to single pixel to any direction etc. Next time you click Edit Background you start from beginning.
If only there were a desktop app…. trying to resize and align the background map on my phone has proven to be…arduous. I got it to ‘good enough’ and left it there.
I have the same problem after the last app update. If your map is too big, then when you open maps to center a photo, Yarbo’s map is not probably centered so you can adjust the photo. On the Yarbo with the small map, I can center the image. But I can’t on the one with the big one.
I think we need help from Yarbo.
Yep. This is exactly what worked. Removed the geofence and here you go - the map is centered and i’m able to try to align it with google image. So yes - if geofence is not symmetrical to the map, then adding a background just don’t work. Although it’s funny that google centers directly to the yard, but puts it in the center of geofenced area.
