Adding sidewalk to work plan.
Delete old sidewalk and created a new one. Created a path to the new sidewalk from a working area. It doesn’t show up in the options for a new work plan.
Does it show up in the list of sidewalks? Maybe try renaming it and see if it shows up. If the list is large, may need to scroll the list, might be hidden below.
Hi there, thanks for reaching out.
Could you please share a bit more information about the issue so we can better assist you? Based on the map we’re seeing, we don’t see any sidewalk listed. If possible, please provide more details about the exact sidewalk, pathway, and work area you’re referring to, or share an updated map or screenshots.
This will help us understand the situation more clearly and provide the right guidance. Thank you!
I checked the sidewalk list and it wasn’t there.
I accidentally replaced the sidewalk with a path.
I’ll redraw it.
Thanks
That makes sense, can’t add those to work plans, unfortunately.
