B1 is getting false positives. It will imprison itself. It first did it in the yard so I took it to the driveway and unfortunately it had false positives there too.
Front camera is disconnected as well. First time I saw the error that I don’t have access to Smart Vision.
They need to fix the camera issue with the backbrace, they put it in the field of view, now they need to electronically (software) mask those areas, so it stops sending warnings. I just can’t believe they send out this stuff so broken on the software side of things.
If the steps above don’t help, try this if you’re up for it. Not for the faint of heart, but some users have commented it has helped resolve issues like this. At least for the mower.
“So looks like the rear cameras/software are the leading culprits with B1. Took off the BBM and “Reverse Blow” still malfunctions with false positives after a 5 min battery pull.
Updated Below in another post-Incorrect
If I disable “Reverse Blow” the false positive do not occur.”
