Battery consumption and voltage
It would be interesting for all users to know how much power a tool is consuming on its battery, and perhaps also to see the voltage to check the battery’s condition! Let me explain! If there’s no change in battery charge for a minute while mowing, removing snow, or even just moving around, there’s a problem! The pin! The blades, or worse! Furthermore, I think that with many more visible options, we would get more information! And we could set a consumption limit to prevent damaging the pins, for example! To avoid any problems, it would also be interesting to add an advanced option for those who would like more control and to customize the robot to their needs!
Thanks for sharing your ideas and explaining the reasoning behind them—they’re very thoughtful. At the moment, though, this isn’t something we’re planning to consider in the short term. We still appreciate you taking the time to share your suggestions, as feedback like this helps inform future discussions and possibilities.
