Front ultrasonic sensors
My mower just started recording “collision occurred” error messages where none occurred. Clearing the error code has no effect. Disconnecting the battery, restarting and cleaning the cameras has no effect. Disconnecting the mower module will let me drive the unit forward. Connected it will only drive backward.
Looking at diagnostics, the FUS has a value of 9999.00,9999.00. I am guessing this is an error code.
Any thoughts?
It could be your front bumper failed, it is somewhat common.
Here is some information on this issue.
Yarbo Wiki
The M1 ultrasonics are disabled. That value represents this.
Is FUS disabled intentionally or is it malfunctioning?
Intentionally for some reason a year or so ago. It was causing more false positives than helping, so they disabled them. Not sure why it hasn’t been fixed but they recently just disabled the MPro ones by default too. Again, same situation. They used to work great. Not sure why they can’t restore the way it used to work.
Thanks Bryan. It’s looking like a winter project
You can disconnect the bumper keep mowing. You just have to know it won’t stop if it hits something. But at least unplugging it will let you know if that is your issue.
If you do mow with bumper disconnected, be sure to turn on all safety features
Thank you. I will try this Sunday. Is it possible to repair the bumper?
I doubt it, but yarbo will send you a free replacement.
You will need a replacement. It’s a molded unit. As @B-Mod said you can disconnect it but make sure you have a NGZ around everything. If it hits something without the bumper it will continue driving and dig a hole.
Well that didn’t go as expected. One of the bumper connectors is stuck inside the housing. No problem I thought. Take out a couple of screws and I can get to it.
100 screws later and I still can’t get at it.
Happy 40th anniversary to me :rofl:
Her present is helping you get the connector out! :joy:
Happened to me once too, had to take the lid off to get it.
What am I missing? The front of the bottom will lift about a half inch but the back barely at all.
Have you reviewed this video? How to Replace Lawn Mower Bumper | Yarbo Wiki
Yes. I’ve gone way beyond that. The bumper connector is stuck inside. I’m trying to get inside the mower deck.
I was able to access it from the top by removing the lid and reaching in. Do you have any better pics of where the issue is?
The bumper connector is caught on something. I was afraid to take top off. The last time I dealt with springs I almost lost a finger.
The top is the way to access it. The connector can get caught in the rubber gromet. In my case, the mower side connector slipped inside the mower. Once the top is removed you’ll be able to reach in and push it back through the hole so you can connect the two.
Yep. You don’t know what you don’t know. I got it. The cable was wrapped around a post.
On the bright side, I learned something new :wink: :sob:
Now to reassemble.
