I bought 2 used units. I have a core with a snowblower, and a core with a mower. These must be 2023 models, serials 0642, and 2546.
I don’t have a Data Center. What are my options. It looks like I can not buy an original Data Center. Now what do I do? Can I install a newer NETRTK system? Without a data center, these are useless.
I need 2 batteries, and 1 unit is missing the battery cover which has the HALO antenna.
What are all the components that I need to get these to work.
Do you have the yellow RTK boxes and the HaLow upgrade kits? Did they give the LoRA boxes and RTK antennas or anything? If not, your options are pretty limited. You could post in the trade hub and see if anyone has one the 23 RTK base stations they could sell. Optionally, you could try using WiFi and NetRTK. If you can get GPS with WiFi and NetRTK, then you could make sure you have a good mesh network in your yard. You can also toggle on cellular and use it that way too. I’d make sure that the units are not activation locked to the previous owner though before buying anything else.
