Mapping Drift and WP005 errors - failed to calculate route
Ticket Id #207488 is sitting there without any response for a week..
==== submitted on 6/7/2026
Dear Yarbo Support Team,
I would like to report an ongoing mapping issue that has become increasingly frustrating after several firmware and app updates.
Current versions:
  • App: 3.18.5 → 3.18.6
  • Firmware: 3.13.11
My current map has been working for mowing operations, and I have multiple saved map backups available (see attached screenshots). However, after recent three updates I have observed two major issues.
1. Map Drift / Coordinate Shift
The entire map appears to have shifted approximately 2–3 feet south compared to the original mapping position.
Because of this shift:
  • area boundaries no longer align correctly with physical lawn edges
  • no-go zones are no longer positioned accurately
  • mowing paths are offset from their original locations
I attempted to use the drift adjustment/calibration functions, but this did not resolve the problem.
The issue is especially confusing because the RTK status appears healthy:
  • RTK Fixed
  • 20 satellites
  • Strong signal
  • Low data latency
Therefore, the drift does not appear to be caused by poor GPS reception.
2. WP005 Errors After Editing Maps (Major Issue)
This is currently the most serious problem.
My existing map continues to work.
However, whenever I:
  • add a new area
  • modify an existing area
  • create a new pathway
  • edit an existing pathway
the system frequently generates WP005 errors.
After these edits, Yarbo often becomes unable to navigate back to the docking station, even though:
  • all areas remain connected
  • pathways are connected correctly
  • pathway widths follow the documented requirements
  • overlap rules have been followed
  • docking station location remains unchanged
I have carefully reviewed the mapping instructions and pathway requirements and believe I am following the recommended procedures.
My question is:
Which map definition is actually considered valid by the system?
Because a previously working map can suddenly become invalid after relatively minor edits.
This makes future map expansion extremely difficult.
Additional Feedback
Currently, restoring a previous map backup also restores an older version of the map structure, but I lose many of my current settings and task configurations.
It would be extremely helpful if future updates could allow:
  • restoration of map geometry only
  • preservation of mowing schedules
  • preservation of work plans
  • preservation of area settings
  • preservation of task configurations
This would make map recovery much more practical.
Attached Information
I have attached:
  • current map screenshots
  • saved map history screenshots
  • RTK diagnostic screenshots
  • version information screenshots
Could your engineering team please review my logs and determine:
  1. Why the map has shifted approximately 2–3 feet.
  2. Why WP005 is generated after editing otherwise valid pathways.
  3. Why Yarbo becomes unable to return to the docking station after map modifications.
  4. Whether this is related to known issues introduced in recent firmware or app updates.
Thank you for your assistance.
Additional observation (6/8/2026)
While attempting to split an existing area and create a new mowing zone, I observed that the new boundary (blue) is shifted significantly relative to the existing boundary (white). The offset is approximately 2–3 feet.
Because of this coordinate mismatch, editing or splitting areas frequently leads to WP005 errors and docking failures.
The existing map still works, but any new modifications become unreliable.
This behavior suggests a coordinate transformation or map synchronization issue rather than an RTK signal problem.
Please see attached screenshot showing the offset between the existing boundary and the newly recorded boundary.
Could engineering review whether this is a known issue associated with recent firmware/app updates?
Have you tried disabling all the path and pathway offsets and see if the error goes away?
First, for the WP005 issue, please try Bryan’s suggestion to see if it can temporarily resolve the problem. The root cause will require further investigation from our support team.
I have asked our team to check your case as soon as possible. Thank you for your patience while we get back to you.
Brian, I read that option however I never turned on any path offset; default was off; never on in my mapping. Transit offset is also affected? I don’t think so. This seems really inherently bugged and so annoying that over 5k autonomous robot cannot handle the mapping issues.
The offsets are new features, and yes they missed some error handling that can cause issues. Disabling all the offsets gets them out of the variable list.
If it makes you feel any better, the $30k ones aren’t doing much better. This is cutting edge technology and there are going to be software and some hardware issues. Hopefully support can nail down what is going on, but I would certainly turn off any new features like the offsets and if you made any recent changes, that could certainly impact things. Edit maps has caused some weird issues. I would consider deleting and remapping the area you want to change. A pain, I know, but if it is more reliable, this could be the better approach for now.
Hey now, that’s illegal!
Pond-driving is a highly patented, protected feature of the Luba 2!
Oh ye olde Scuba 2, eh!
Yes, even disabling any offsets won’t help the WP 005 error.
We got another swimmer here guys…
Seen quite a few Lymows taking a swim break.
Probably one of the new one pluses with the over heating deck motor controller issue, she is just self cooling.
Are Yarbos next, cooling off the overheated battery?
Let’s hope not. That won’t be as easy to remove from the drink.
Getting worse. After following the instructions of reboot DC and yarbo. Now lost wifi connection and cannot control remotely. They checked they can see my yarbo is on and connected but my app doesn’t see it. Only Bluetooth connection is working nearby…. So frustrated.. anyone has this issue? All numbers; figures looks fine; even rover has green to my wifi. But the app is not working.. I removed the and reinstalled everything; no luck!!
Unfortunately, that sounds like something support is going to have to resolve.
know that feeling. :rofl:
Is that the new Pool Cleaning head?
He’s just staring back at you like… What?
Sorry for the inconvenience caused. I will follow up on your ticket regarding this issue.
Would you really and please follow this issue with ticket number; #207488???
It’s been sitting in 2 weeks without any reply from you!!!
