No power to Modules
I went to use the lawnmower tonight and the lawnmower module doesn’t have any power, the blades won’t turn, the lights won’t turn on. I tried turning it off and back on, unplugged the battery for 5 minutes. I also put the snowblower on with the same results. The rest of the core seems fine, it moves with the remote and will start a plan, just won’t mow anything
As mentioned in another post, try checking for corrosion on the module cable and connectors
Hi there, you can refer to Bryan’s suggestion to check the module cable and connectors first.
Also, please submit a support ticket and include detailed information about the issue (such as what you’ve tried so far, along with any photos or videos if possible), so our team can better investigate this for you.
