Pro RTK antenna
When Yarbo is resting under an apple tree, these are values
And this is how it looks in free area
I think it’s mostly the HDOP there, as anything over 2 is unusable. Quality is also less than 0.5. But you need at least 4 shared satellites with the DC for it to be able to try and figure out its coordinates. With only 6 L2, there doesn’t appear to be enough shared quality satellites for it to go to status 4. I’d try it at a different time of day, maybe even night time. The daytime warming of the atmosphere can generate interference.
Some AI generated info:
For the most reliable RTK performance in areas with tree cover, aim to operate in the early morning (before 12 PM) or overnight, while avoiding early afternoons. These off-peak times experience reduced atmospheric (ionospheric) interference and provide a better configuration of overhead satellites
I replaced my stock antennas with HA-609s (slightly different, larger, and supposedly stronger than Yarbo’s pro version) and did a few tests. The spotty areas are absolutely better however it isn’t a miracle or anything. But considering the cost and no downsides I can see, it seems to be a no-brainer.
I remapped one of the difficult areas, where several times before the area had jagged lines where the GPS signal would come and go, and this is the first time it was perfectly smooth.
I did have to modify the flexible mounts as the new antenna is quite a bit larger than the stock. I can make this new version available if anyone wants to print some for themselves.
Here’s what they look like and a before/after in a particularly difficult area:
I would say my results are the same, better but not great. I was hoping it would help my unit get off the dock without me moving it, it has a little but not much. I don’t really have any bad spots in my yard, the worst is probably right up next to my garage door snowblowing in the winter, but I won’t know if that area is better for another couple months down the road.
The problem with the HA-609’s vs the Pro antennas is they are a generic antenna made by many different manufacturers and specs can vary. The Pro antennas are working pretty well for me and definitely helped my core get off the dock in an obstructed area whereas before I would have to wait 5-10 mins sometimes or drive it off the dock to get signal.
Are you saying Yarbo had a custom antenna made for them?
Not to my knowledge. I guess anything is possible and things are always subject to change. However, the current Pro antennas are not random manufacturer generics like the HA-609s are.
I am pretty sure a user posted the antenna they got from yarbo (it was one of the first) was a HA-609, as it was on the antenna. Not saying they stuck with it, but I think that is how this HA-609 info came out.
Well, it might be that Pro antennas are some of generic ones… as regular antennas are just HA201
Maybe they buy them in large lots and screen/bin them based on a particular part’s performance. Though they seemed to have their fair share of bad original antennas, so it doesn’t seem like that’s how they operate.
First test ones were, but the ones they shipped out and that are coming with the new cores are not.
Send me your set and I will test them next to mine, lol. :rofl:
Btw - maybe @Yarbo-Forum knows when the pro antennas will be shipped?
Bought them on https://eu.yarbo.com/ almost month ago and status for antennas still is Pending.
I received my Pro Antennas over the last couple of days. (2 out of 3 ordered so far).
Are people installing them on the flex mounts or just to the short mounts? They feel really tall on top of the flex mounts.
I would recommend on the flex mounts. The low mounts won’t flex and will shear if it comes into contact with something. I have mine on the flex mounts.
Post your pre and post numbers with your old v new antennas! If you wants to :sign_of_the_horns:t4:.
We recommend installing them on the flex mounts.
Hi there, I’ve checked your order in our system, and it is currently in transit.
Please kindly allow some additional time for the shipment to arrive. Thank you for your patience and understanding.
Ok. I’ve.received my pro antennas.
Drove it to open area and checked the diag with ha-609 and Pro antennas
Luckily there is no decrease in gnss signal.
Let’s see how will it perform in action ner walls, under trees etc.
Ha-609
Pro antenna
