To change the snow throw direction we go to Edit Map, Area Icon, Ellipses for the area, and select ‘Redraw Directions’.
‘Redraw Directions’ should be renamed. If you want to use that verbiage it should be ‘Redraw Direction’. A better label would be something like ‘Select Snow Throw Direction’. If space is an issue maybe just ‘Throw Direction’
Anything is better than Redraw Directions. That makes it sound like you want to remap or tell Yarbo to do something.
Fair enough. How about if the leaf blower is attached have it say A and if the snow blower have it say B. I’m pretty sure computers can do that sort of thing.
Hi there, thanks for sharing your suggestion about the naming. I understand what you mean. I’ll pass this feedback along to our UI/UX designer so we can review whether the wording should be adjusted. Thank you for bringing this up!
The trimmer also uses the same yellow line for trimming edge. This is most likely when the change was made. I am sure it was the least ambiguous way to address it.
