Snowblower Near Garage
Has anyone figured out away to snowblow close to your garage? Whenever I run it, it leaves a wall of snow around my doors. If I map it closer to the doors, it will hit the jut out in the middle or the doors when it turns. I have tried both slope and circle map pattern. What I have to do is every once in a while during the storm I open the doors and push the snow to the middle with a shovel, but ideally I wouldn’t have to do that.
I made a comment on your FB post too, but you could try tweaking your snow throw line back a little. Don’t run it all the way to the end of the perimeter and see if that helps. The new firmware has made a considerable improvement for me in this same area, but it does still throw a little snow on mine too. Hopefully they will get this sorted out.
