Dead ends are carefully crafted and ordered within a work plan to ensure portions of grass are cut without Yarbo hitting things, or going down the line backwards. Then, if you disable a dead end within that plan and save, the dead end gets moved down to below all enabled elements, and order is disrupted. Don’t do this, Yarbo. Stop changing things. This is known as a “side effect.” Maintain consistency.
Thank you for your feedback! We will pass this along to our product team for consideration. The current design is aimed at keeping the interface easy to navigate by displaying all the active elements, but we understand your use case. We will carefully evaluate which approach will be more convenient for the majority of users. Thanks again for sharing your thoughts with us!
I agree. Just because something gets disabled that shouldn’t cause the order to change. This happens quite a bit and it is really annoying. You could add a checkbox to keep the current order or move disabled items to the bottom.
