Unable to return to base
My core keeps having an issue where it cannot return to base when its blades get stuck. The blades getting stuck are not really a concern, but the fact that it can’t find its way back is a bit confusing to me.
Has anyone else seen this issue?
Do you ever get that error when it finishes that area?
Not that I recall. But I’ll pay attention when it finishes this time and let you know.
I know if I drive it to another work zone it does fine or even if I drive it to the eastern area of the current work zone it’s in it does fine. It seems to only happen on the western side of the pond, even though there are clear spaces in the work plan on both sides of the pond and there’s even a pathway across the driveway to another work area. It could take.
Pay attention if it’s within an overlap when it throws the error. Overlaps it tends to get confused which layer it’s on.
Hey Bryan,
Yes there are 3 overlapping areas close to where it had a problem. I can easily delete the other two, they are left over from when I unsuccessfully attempted to use tow-mode to clean up the pine cones that are now blocking my cutting blades. Ah, irony.
Thank you,
Jeff
Hi there, have you had a chance to try the suggestions provided by our Support team? Are you still experiencing the issue?
If the issue has not been resolved, please keep us updated with any additional details so that we can further investigate and assist you.
Hi Yarbo-Forum. Deleting the overlapping areas solved the problem. Sorry I forgot to come back and make updates here. Will do so now.
