# Use accelerometers to determine position when goa is not available
**URL:** <https://forum.yarbo.com/t/use-accelerometers-to-determine-position-when-goa-is-not-available/1680>\
**Category:** Suggestion and Feature Requests\
**Created:** [May 12, 2025, 2:11am UTC](https://forum.yarbo.com/t/use-accelerometers-to-determine-position-when-goa-is-not-available/1680 "2025-05-12T02:11:01Z")\
**Posts on this page:** 1\
**Showing post:** 3
<div class="post-metadata">
**Author:** ![mp-baden](https://yyz1.discourse-cdn.com/flex007/user_avatar/forum.yarbo.com/mp-baden/32/759_2.png) [@mp-baden](https://forum.yarbo.com/u/mp-baden)\
**Post date:** [May 14, 2025, 7:17pm UTC](https://forum.yarbo.com/t/use-accelerometers-to-determine-position-when-goa-is-not-available/1680/3 "2025-05-14T19:17:41Z")
</div>
Same feature request here:
> [@GPS-less navigation possible?](https://forum.yarbo.com/t/gps-less-navigation-possible/1240):
> Hello there, I am living on a mountainside with an area about 600-800m^2. I have 3 trees there on the side. I’ve teached my yarbo to mow this area and marked every tree as a no-go-area. The result is more or less okay, but after all there are 3-4 lines of gras, which my yarbo missed mowing. Meaning a line about 5-6m long and 10-20cm wide. This missed lines are not under the trees, so I wonder what caused my yarbo to miss this lines. There seems to be no logic yet, to do a GPS-less navigation, m…
There is currently one problem:
When loosing GPS especially directly under a tree, I had the situation that yarbo waits forever for a valid GPS signal. But this will end in a dead end cause of the tree (no GPS). So I had to manually move yarbo away from tree and start mowing again.
A currently workaround: I added a larger no go area around tree to avoid GPS dead end.
_[View the full topic](https://forum.yarbo.com/t/use-accelerometers-to-determine-position-when-goa-is-not-available/1680)._
