Weighted Side Plates received
Beefy! Hopefully this winter they help.
Google Photo album, click for more:
Google Photos
One other thing I’ve been staring at is that the winter tracks put the studs in the outside of the tracks where there is 0 support…at least the drive cogs have some outwards horizontal supports but they almost could use a row of studs along the centerline if they’re really looking for ice traction. The studs also could be more recessed into the tracks but we’ll see… that’s why I’m thinking some people see nearly the same performance or perhaps even worse performance with the studs, they allow them to dig and loosen up the snowpack more without providing all that much traction.
Thank you for sharing. Mine are ordered just waiting on shipping notification. :crossed_fingers:
The packaging choices were interesting…:sweat_smile:
So what is the weight difference between regular steel plates and the weighted ones?
These plates add about 10lbs per side to the core. The factory plates I don’t think they add much at all.
10lbs per side? Wow. Thats pretty beefy.
Why use those in the summer though? I’d think they would cause more turf damage.
They’d probably be great for snowblower use though. Maybe I’ll pick up a set before winter arrives.
I wish they weighed about double that, for use in the winter. The snowblower weighs a bunch and is held pretty far out from the core. And add to that any heavy wet snow stuck to it, and in it.
@rgloverii Great! now you have me wondering if I’m jumping out of the frying pan into the fire. :smiling_face_with_tear:
I ordered them for mowing several 32~34° hills. No matter which direction I mow the hills, there are currently turns that jackknife mower-n-core. The jackknife causes most of the treads to be off the ground thereby causing the limited contact surface to tear up the lawn.
There are a couple of people on here who swear they made a difference for the hills with the mower.
Give’em a try and see what happens! If nothing else, they’ll come in handy during the winter.
Hopefully the benefits will outweigh the (potential) drawbacks.
Please keep us posted. I’m thinking about buying a set (for winter) myself.
I see what you did there. :eyes:
Yes I’ll report back here on my results.
Sorry to hear about the issue you’re seeing on those steeper slopes.
Please keep us posted on how things go after you install the weight plates. In the meantime, you could also try adjusting the route angle so Yarbo makes its turns on a relatively flatter part of the slope where possible. Setting a route rotation degree between plans may also help avoid having Yarbo turn in exactly the same spot every time, which could reduce repeated turf damage in those areas.
Assuming we can ban 0 turns I would think they would be helpful on steeper terrain​:+1:
It’s september here, we could get snow any day :joy:
I’m not ready for snow season yet!
Napoleon Dynamite: Bring It!
