Which module is most suited most for autonomous rolling weeds?
Hi,
We’ve built a hardware prototype based on the Rolofaca concept (crimper rolling / weed pressing) to handle high weeds in pathways across a 10+ hectare young forest area.
The setup:
  • Designed a custom 3D-printed nose that connects perfectly to the 4 pins of Yarbo’s lifting system.
  • The roller is positioned in front between the winter tracks to use Yarbo’s full weight for maximum pressure on the weeds.
  • Manual control works like a charm.
The software roadblock: We need Yarbo to autonomously follow pathways/patrol routes (covering about 2-3 km per hectare). Total area bigger than 10 ha!
  • Currently, pathing/patrolling only seems to work with a SAM module.
  • The features of the Mower module could fit this rolling application better than the SAM module, but I don’t have (or need) the actual mower hardware.
The hardware is (almost) ready, still several ideas for improving, but the software limitations are holding this project back. Is there any way to trick the system into using mower/patrol paths without the official modules attached, or is anyone from Yarbo open to creating a workaround/custom firmware for this kind of application?
Rolling instead of mowing has huge environmental benefits compared to mowing, and the Yarbo as a drivetrain is perfect for it if we can solve the software side. Any thoughts or advice?
Could you incorporate the SAM components into your design? That way it thinks a SAM module is attached and offers waypoints and patrol lines?
