Wireless charging pickup coil loose?
Is it supposed to have play?
That has always had some play in it. Are you having an issue?
Mine has zero play. (Finally something I can test with a fried core). :wink:
Or maybe the pickup coil is what’s fried and welded into place.
You confirmed the screws aren’t backed out, yes?
No issue yet, just noticed it wiggly when I was cleaning the freezing slush off the bottom.
Not closely, didn’t have gloves on, are the little allen bolts what hold it up or does it affix by other means? I’m going to check the wiki for an exploded parts diagram/assembly wiki, just wanted to know if I need to stop using it immediately
Are these blocks/screws what hold it up? The whole underside was caked full of snow, but maybe after a good charging session it’ll clear out for a better look today😁
Replacement core fresh out of the box.
Definitely has wiggle/jiggle room.
Hi there, could you please submit a support ticket regarding this issue and include a clear picture of that part? We suspect there may be some bolts that have come loose, and the photo will help us verify it.
Submitted
Google Photos
Support just confirmed that’s normalšŸ‘
Good to know, mine has always had play in it like that.
