Yarbo traction/floatation
I would like to see available for purchase wider sprocket/iders and wider track for better floatation on soft ground. An option at purchase or as an option to purchase later perhaps up to 50% wider than existing drive sprockets and idlers. These could help distribute the weight to prevent turf damage during the wetter seasons
Hi there, thanks for sharing your suggestion.
A wider track design could potentially help improve performance on softer ground and reduce turf impact during wetter seasons. Currently, we don’t have plans to redesign the track system or offer a wider track option, but we really appreciate you sharing this idea.
We’ll continue to monitor user interest and feedback on this type of improvement as we look for ways to enhance the overall Yarbo experience.
Makes sense, wider tracks are the standard fix for ground pressure on soft turf. The engineering catch is that a 50% wider track usually needs more than just wider sprockets, the drive train and chassis clearances have to accommodate it, plus turning resistance goes up. Still a solid request for wet-season users though. Might be worth framing it as an official accessory option so Yarbo can spec it properly rather than a DIY swap.
Adding idlers/sliders to the center of the current track design could help, especially in winter the front and rear portions of the tracks dig and the center of the track just flexes upward until the core bottoms out on the debris guards.
Said this for a long time. Make the front and rear wheels match the current front wheel design and put the idler (or smaller version) in the center.
What about redesigning the footprint of the existing tracks to a more broken up tread pattern instead of the 90% flat rubber contact with turf. Look into turf tire tread patterns and work with that.
I am not sure why they did not give it more ground clearance? This thing gets hung up bad in sticky snow.
And tree roots
Right, and the turning-resistance point is the one that bites hardest, wider tracks increase the scrub area during skid-steer turns, so you’re fighting more lateral friction and drawing more current, which can hit runtime and motor load on soft ground. Framing it as an official accessory is smart because Yarbo can then spec the drivetrain, clearances, and turning calibration around it rather than users discovering the side effects the hard way. A properly engineered wide-track kit for wet-season use would land better than a DIY sprocket swap. Solid request.
Yarbo’s belly needs to be close to the ground for the wireless charging to work efficiently with the current charging dock’s design.
Personally, I’d redesign the dock to allow for greater Yarbo ground clearance.
I’m sure it’s a trade off between being top heavy, charging, and being able to clean off the dock of snow.
There are many design changes that could have enabled the rover to have more ground clearance, but sadly they did not choose any of those options and instead we deal with a product that gets hung up regularly.
