Global Area Settings
A user makes work areas. Currently the same work areas are shared for all modules.
It is my understanding that work areas will increase to be by module.
Regardless:
  • please add a toggle switch in each work area settings page defaulted on to global settings.
  • Then please add a global area settings page so for example:
  • Example 1: you can choose 3.5” high cutting for m1 and it configures all work areas that are toggle on for global.
  • Example 2: some firmware update comes out and now moderate bypass is acting odd. Let me go into global settings once and make all toggle on work areas change to gentle contact
  • Example 3: checkboard not working out. Well I don’t need to go to each work area anymore. Just go to global and change them all to diamond from one place.
Could do the same for pathways and no gos.
I worked on a product long ago that had “Apply” and “Global Apply” options. I am going to raise my cutting height eventually and see a “Global Apply” as useful so my mapped items of a particular type (Areas, Deadends, or Pathways) get the bump. Or select the mapped items you want changed from a list and apply the change to those.
I think I have something approaching 30 Areas and approaching a dozen Deadends. So, yeah.
Thank you for your suggestion! We’ve also received similar feature requests regarding global settings. We’ll definitely pass your idea along to the product team and carefully consider what should be included in the global settings.
I could also see a global setting for mowing height. Some reasons:
  • Changed from straight blades to razor blades or vice versa
  • Changed from M1 to Pro or vice versa
  • Grass is growing slow or fast now
  • Leaves are on the ground now
  • etc
I could see this as a global height setting, or a plan height setting, or even a add 0.5” to all my mowing plans adjustment.
