Going out of bounds
Uggg this keeps happening to me in the same area, and it gets stuck in the woods when it goes out of the perimeter for no reason. I’ll try remapping that area when I’m able but it shouldn’t be doing this. Just wanted to share in case it could be helpful.
Hopefully the remapping will fix it but it’s a bit frustrating because it is mapped correctly.
Extend that pathway 3ft past all the overlaps on each side. See if that helps.
Hi there, this should not happen. In some cases, overlapping map areas can cause unexpected behavior.
Could you please try Bryan’s suggestion first and see if it helps resolve the issue? If the issue still persists, please submit a support ticket so our team can investigate further and assist you.
