I have several narrow (~1 yarbo wide) strips of grass in my yard that could be best mowed if treated as one-way paths, not dead ends. (I do not need the wear and tear on the lawn when it backs up and there is an existing area at both ends.)
How can I map them?
Could you map them as pathways between the areas and then drop no go zones in front of the entrances to the other pathways. You can enable those when you want it to go down those pathways instead. Disable them when you need it to go another way.
It would be really nice if you could disable the reverse on a dead end that connected two areas or include pathways in work plans.
