Setting up an over layer or sort of master layer on top of the “areas” to be mowed. Utilizing a master over layer which gets broken down into smaller manageable areas that wouldn’t need a restricting pathway, this way yarbo has full access to the master layer and can move freely between areas so pathways would not be necessary at all.
Thank you for your suggestion! I’d like to confirm your main goal for requesting this feature. Are you hoping to prevent potential lawn damage caused by Yarbo repeatedly using the same pathways? Or is there another purpose you have in mind? Understanding your objective will help us better evaluate the idea.
Both and more, I have a long driveway and I don’t want to use a pathway because of damage but also because of its length i don’t want yarbo to have to go to the very and or middle or wherewver the pathway is for it to be able to cross. If yarbo had one single “master” area that it had total access to and then just smaller areas for mowing it could utilize and line or path it sees fit to travel. Also being able to section areas utilizing a single line would help with some grass getting mowed twice or some not at all trying to draw areas boundries with the same line.
Thanks for sharing your thoughts and detailed explanation. I’ll pass this along to our product team for their consideration. Feedback like yours is really helpful as we continue to improve the user experience.
