Stop mowing at night
So reading this thread there is no way to automatically have it mow a large area over two days?
Thanks guys. I submitted a ticket #118316. I backed it onto the charging pad and did a restart. Then I commanded a charge and it began charging. It is now 100% charged but the GPS, which turned green 30 minutes ago, is now yellow. on diagnostics L2 shows “0” but satellites show 21. I think that number is what is observed by the data center.
That number is from your rover. However, you could try powering off the DC and pull the battery cable for 5 mins on the core. Power up DC and then core and see if your GPS comes back. Your L2 shouldn’t be zero. If it is after the power up, check your right side antenna on the core. Make sure it looks tight and undamaged. If it is, swap left to right and right to left and see if the numbers in diagnostics change at all. If the problem moves, you have a broken antenna. If it stays the same, it’s most likely something else. Support will most likely have you do this to troubleshoot that issue. So I would document your results in the ticket preemptively. Save some back and forth time.
You can as long as you don’t care if it works the entire time. If you want it to pause for anything other than routine auto recharge, you can’t automatically do it.
Bryan,
Thanks. I will get on this first thing tomorrow. I have a function to attend this evening😞
When I’m mowing a large area and it gets dark, I pause the work plan and bring up the controller and hit recharge. Yarbo goes to the charging station and recharges and waits. I then resume the work area after the dew has burned off.
It’s not automatic but it works for me.
I would and have done the same thing.
I do the same thing. Both with Yarbo and with Luba. Just manually postpone the job until the next day.
@kmurray6113 Hi there, I’m sorry to hear about the issue you’ve experienced. Our support team suspects this may be related to the right antenna. Could you please follow the troubleshooting steps provided by our team and let us know the results through your support ticket?
We truly appreciate your cooperation and patience as we work to resolve this for you.
I replied this morning. They will get back to later to I assume.
I think you meant, musical fruit.
