Thread Solution Summary at top, Close the thread if solution is found.
Hello is there anyway to move or choose a response that most accurately answers a thread to the top? It would be very beneficial to see the “answer” to some of these posts without having to read through the entire thread. The bracket protecting human fingers and animals from reaching the blades would easily be satisfied with a solution. I understand not all are as simple but would be a good place to start.
In other discourse forums I have used responses can be marked with a solution tag which pins that response at the top under the original post. I dont see that as an option in this forum.
The forum administrators mark it as a solution but I don’t recall if it pins it at the top
Thank you for the suggestion — it’s a great point.
The forum does have a “Solved” feature that allows an answer to be marked as the accepted solution. Once marked, that response will automatically appear at the top of the thread, making it easier for everyone to find the most helpful reply — like in this example:
Previously, only administrators had access to this feature, but based on feedback like yours, we’ve now enabled it for topic authors as well. If you’ve started a thread, you can now mark any reply as the solution.
We really appreciate your input in helping improve the forum as a better platform for discussion and clarity.
Great addition! Thanks for enabling that.
