Please add a pause button to the app while the rover is charging during a work plan. Since the scheduling feature does not stop multiday plans at night, I have to manually pause my long plans. If it’s on the charger, I have to either wait for it to end charging before pausing the plan. Or I can manually resume off the charger, wait for it to start moving, then send it back to the charger, which will pause the work plan overnight. I can also activate the manual controller which pauses it but a simple pause button would be much cleaner. This was requested by @brysach2 in the new feature forum over a year ago and it seems like a bug that needs to be fixed instead of a new feature.
They recently added the ability to return at stop time. The plan will stay paused and as long as you set a schedule for the next day to run the same work plan, it will resume at the scheduled start time where it left off. Takes a little planning out, but I think you can achieve what you want.
Not entirely sure this works. We’ve started or restarted schedules and if it’s charging through the end of it’s schedule time for that day, it’s still been going out to mow.
If you know the times that is happening, I would open a ticket and note the times/days so they can track it down and fix it.
Hi there, this may require further investigation from our support team. As Bryan suggested, please feel free to submit a support ticket with more details so our team can look into it further.
