I have a Yarbo, Lymow and Mammotion Luba. The Mammotion Luba has a great feature to set a “No Mow Period” where the mowing automatically pauses and the mower returns to charge. With the Mammotion Luba I use this all the time so prevent it from mowing at night when the grass is wet with dew.
Yarbo has a “No Charge Period” in the Work Preference Settings which may be to avoid charging during peak periods. I would love it if there was a “No Mow Period”.
I’ve tried work arounds like manually trying to pause it and restart it the next morning. The problem happens when I try to pause it and the mower is charging I can’t charge it. So I have to trick it by resuming it, pausing it right away, then try to get it to return to the charging station. Sometimes this works, other times it crashes and I have half mowed yard and have to start over.
