Could we have color codes on the machine to indicate when there are problems, or even have them flash rapidly? And perhaps give us the option to be notified from our cell phones by sending a text alert or making a simple call, since we don’t always have the chance to read the simple alerts on our phones. even opening an internet link that corresponds to an action on a server ![]()
Thanks for the suggestion—this is a thoughtful idea. If more users express interest in this feature, I’ll be happy to share it with our product team for consideration.
Talking about Alerts. Anyone knows about this notification from Yarbo “Automated schedule generated for efficient operation.” Now I get this noted many times a day. I have not set Yarbo for any schedule to do anything.
The other question I have is when I reviewed the battery info under Privacy and Security. One bullet item says “Avoid overcharging your device for preventing overheating, and unplug it once it is fully charged”. Though when I was checking the status of the battery condition and Yarbo was sitting in the garage I saw a note says the battery is cold and it is warming up, then will continue charging. So which way to go leave it plugged during the cold season or unplug it, so it does not over charge?
If you have snowfall notifications enabled, the message is misleading if you don’t have the auto schedule also enabled. If it’s not set to auto schedule, you can ignore the message.
The battery is safe to leave charging. The BMS will maintain it at the optimal state of charge. When temps are below freezing, it will heat the battery periodically when the core is on so that charging is at optimal and safe temps. You can also store it, just make sure it gets charged for 15 mins every 3 months. Totally up to you.
Thanks Bryan, for both responses. Good to know
