Allow options for leaving a dead end within a known area
When using a dead end within a known area, we should be able o tell yarbo where it can “exit” or behave when completed. To help reduce ground wear and allow for easier maneuvering.
Example - have a dead end going up a hill to mow along stairs which is within a mow area. However yarbo when trying to back down the hill will often get stuck because it will drift and bump the wall. If I could tell yarbo that it does t have to reverse, but just “continue forwards” it would t have the issue.
It almost is a “mow line” that toe action, where it’s not an “area” and isn’t a “dead end”
There is already something like this. Unfortunately, it only exists for the snowblower. Why the lawnmower doesn’t have it only Yarbo knows. It’s been asked for dozens of times.
Don’t forget to upvote.
How about just being able to add pathways as part of a plan? So it has to cross them.
Also been asked for many, many times over the years.
Can you mow along a memory path?
You can mow with the trimmer memory path. Memory paths need to be supported across all modules and not just for trimmer or tow mode.
As long as they don’t do them in reverse
That is the current hazard, indeed.
Ah so in tow mode you can’t activate the blades, you need the trimmer mounted to run a memory path outside of tow mode? :melting_face:
Yes, unfortunately
Thanks for sharing your suggestion. I’ve noticed your strong interest in this topic, as well as the additional feedback and discussion from other users.
We have shared this request with our product team before. However, based on their evaluation at the time, we did not move forward with this direction.
I’ll make sure to share your feedback, along with the other users’ suggestions and use cases, with the team again for further review.
