Anyone Know How to Mow a Ditch Bank in Set Direction
Anyone know how to get Yarbo to mow a ditch bank like this? I made the street side of the ditch bank its own zone so I would know when the Yarbo is near the road and could pay more attention to it if necessary. The rest of the front yard is its own separate zone down to the middle of the ditch (see mowed grass on left of pic). I want Yarbo to only
go back and forth on the outside edge of the ditch bank (see arrows for directions) because that should keep it from jackknifing itself everytime it mows downhill and then folds itself up between the ditch banks causing it to suspend operations until I go back out there to check on it.
Sounds like you may want to turn off lift detection if that is what is causing it to suspend operations.
You can map that as dead ends or you can map that as an area and then adjust the route angle to get the pattern you want. I do this in one of my areas and I turned off all rotations and path offsets so that is consistently runs the same pattern.
