I have 1 area left that I haven’t mowed yet. It’s labeled ‘front west’, in case you can look at it.
I have a pathway going into it, (had 2 at one point testing). Yarbo will follow the path to get into the area, but at the end, will just keep going back and forth, it turns a little and just keeps doing that. Not sure what is going on. All my other areas are working just fine.
What is your Obstacle Avoidance setting? Try setting it to Gentle Contact if it isn’t – that turns off Vision.
We’re sorry to hear about the abnormal behavior with your Yarbo. To help resolve the issue more efficiently, we’ve created a support ticket (#80720) for you. Could you kindly add the estimated timestamp for when you noticed the problem to your support ticket? This will help our support team analyze the logs and identify the root cause. Thank you for your understanding!
As an aside, if “gentle contact” resolves it, put a new “No Vision” area around that location, and it’ll stop using the cams there.
