Application bug?
Hello. Today app says i should reconnect.
But it was stuck on a Grey page. No login input.
I ve try to uninstall and install it was the same.
Any ideas?
Oh, if you mean log in again (not “reconnect”), and you get stuck on a gray page, I understand that setting the phone language to English works around this for now (not sure how to do that).
I’ve change the phone language.
It’s the same but app stay in french after reinstall…
It’s the same on my tab witch there is no cache first install to test.
Hi
Delete the app. Reboot. Change phone language to English. Reboot. Install the app. Then you should be able to login.
Do NOT use any French accents on anything (especially not area names). We have had report of Danish, German, French using their language characters to mess with the app. We already reported it to @Yarbo-Forum and they said they would fix this.
See also this thread: Map disconnected error - #2 by Micke
Hi Mike.
Thanks.
I’ve check it. It has work on may second phone.
I don’t manage to do the same in my primary. App stay in french. i ve clear data and cache.
I don’t now were is it. And this app is not allowed to change language in android param.
It should be from the app.
Should wait hotfix for this.
Hum… Not sure for Android. Submit a ticket to report the bug?
Yes i’ve done a ticket this morning.
My 2 phone and tablet were Android. But primary one and tablet are samsung with Oneui.
Secondari is a Zenphone witch is more like Android stock.
I don’t manage to use App in English on samsung even after delete french from system.
App stay in french and stuck before log page.
Ticket Id
#107786
Hi there! Sorry for the inconvenience this has caused. Our team is aware of the issue and currently working on a hotfix to resolve it. Thank you for your patience!
In android some app allow to change language from Android parameter option, not only from the app.
It would be good to use this. It’s hard to go in app to change option if you can’t log in.
Here’s a workaround that may help resolve the current issue, though we understand it’s a bit inconvenient:
  1. Delete the Yarbo app.
  2. Change your phone’s system language to English.
  3. Reinstall the Yarbo app, log in, and then set the app language to French.
  4. Finally, switch your phone’s system language back to French.
We hope this helps, and we truly appreciate your patience!
This don’t work on Samsung.
I’ve also del cache.
Reboot phone after all.
When it install app stay in french… After 2 hours i give up :slight_smile:
I’ve an old phone i’ve done this and it work. I use app on this phone in english.
I’ll wait for the fix.
I works with last app
Fresh app update this morning that might help with this issue. Please keep us posted if the fix helps.
The fix is ok fron franchement app.
Thanks
Awesome!
