Ask Me Anything. I’m Allen, CEO and Founder of Yarbo
Hi,
I have two yarbos and I have been receiving conflicting info from support via email vs support on Facebook.
One is telling me I should be sharing one data center or there will be issues but there are no directions how to pair both yarbos to one data center. This one is also telling me using two data centers can have compromises and that each data center needs to be on separate routers without any explanation. From a network perspective I don’t understand this or the lack of clarity. Also, no other user I have spoken to with multiple yarbos using multiple data centers has them on separate routers. Nor have any of them received this direction to have each data center on it’s own router.
The other yarbo support is saying that I should use separate data centers for a 1:1 ratio of data center to core. This Facebook support states sharing a data center could cause issues and compromises. Again no explanation of these issues.
Both support outlets are fully contradicting one another.
What is the right way (best possible way) to install multiple yarbos:
  • one data per yarbo?
  • Share a data center across up to 8 yarbos?
  • How do you share a data center? When I tried one data center only one core worked. What are the instructions to pair both cores to the one data center?
  • If you have for example two data center and two cores, why would you need each data center on a different router? Please provide directions as support is not. Do they mean each data center should be on its own vlan? Does each data center need a static ip? Are there network settings that should be enabled/disabled?
  • Some users seem to be sharing one data center and state support programmed it to do so. Most seem to have one data center per core. Which one has the least compromise? What are the compromises?
Currently i have two data centers and two cores. Each data center is plugged into the Poe switch on my network rack. Each data center is on the same default network.
While some have explained to me that Yarbo doesn’t “officially” support having multiple yarbos there shouldn’t be conflicting directions from support. Can you provide the best optimization please?
Best Regards,
Matt
Thank you for bringing this up—and I truly apologize for the delay.
You’re absolutely right that we need to do better when it comes to the supply chain for replacement parts. Earlier this year, we underestimated demand and faced allocation issues that delayed restocking at our U.S. warehouse. We’ve since taken steps to restructure and improve this process to ensure greater reliability moving forward.
I’ve confirmed with the team that shipments for the U.S. region are scheduled for next week. If you can share your order number, I’ll make sure someone follows up with you directly.
Hi,
Thank you for your kind words—and for recognizing the potential of what we’re building. It means a lot.
You’ve touched on a real challenge, not just for us, but across the industry. Heavy, wet snow is notoriously difficult for any electric snowblower to handle. While your Ariens sets a high bar, we see that as a benchmark worth aiming for.
We’re actively investing in long-term R&D, including partnerships with research institutions, to explore higher-performance auger systems and more powerful drive mechanisms. At the same time, we’re optimizing battery efficiency and path planning to better support higher-load operations without compromising runtime.
This won’t be an overnight fix, but it’s a direction we’re fully committed to—and your feedback helps us stay focused on what matters most.
Good morning,
Thank you for using both the Snow Blower and Mower Modules—and for the thoughtful question.
The noise actually doesn’t come from the motor itself, but from the reducer. We use high-torque, all-metal gear reducers to handle the demands of heavier outdoor work, which naturally results in more noise compared to consumer-grade solutions like the Husqvarna Automower.
That said, we’ve made improvements to the precision of the gear manufacturing process, and I’m happy to share that this has already led to noticeable noise reduction. In our next hardware revision, the sound level will be significantly lower—without sacrificing power or durability.
Appreciate you raising this.
Allen, do you know the plans for handling multiple modules on the maps? Given the overlaps I have (mower Areas completely overlapping snowblower Areas on my lawn), my map has become unworkable – I cannot re-create Pathways without deleting mapped overlapping areas first. And there are other associated things where the snowblower will navigate using a Pathway I want for the mower, that kind of thing.
I understand Development is looking at labeling (and then filtering?) and other small changes, but I don’t know what’s up. I’m moving from winter to summer, and I’m seeing this now.
Great question.
Yarbo uses a custom-engineered lithium-ion battery pack based on NCM chemistry (Nickel, Cobalt, Manganese), not LiFePO4. We chose this for its better energy density and cold-weather performance—critical for all-season outdoor use.
The pack is designed in-house with enhanced thermal management and protective circuitry to ensure consistent, reliable performance even in harsh environments.
Can you confirm the regular/daily towing capacity? In a livestream it was recently revealed additional testing by Yarbo engineers raised it from 500 pounds to 1000, which is insane but really shows some capability. Others still stick to the 500 pound regular/daily towing number.
Thanks for your reply.
Umm.. How does towing additional weight improve the grip on the tracks?
It seems to make more sense to somehow add vertical loads (normal forces) directly onto the tracks to improve the frictional load, hence increase the traction. [frictional force= coefficient of friction x normal forces] if I remember my engineering formula correctly. I believe the key is the normal forces onto the tracks is required to increase traction besides changing the design on the tracks. Pulling more weight seems to remove power from the motor that is providing forward thrust to push into the snow piles.
Is there a compatible connector on the current battery that would work with the charger to charge the battery when it is not in the robot?
Since the robot is out in the open at the docking station; during a heavy snow storm it is buried in the snow (or soak in heavy rain) . Perhaps, it would be wise to build a shelter to keep yarbo from getting buried in snow. However, the shelter could block the signals Yarbo needs to operate, any suggestions to deal with this situation to give Yarbo some protection from severe weather beside storing it in the garage away from the docking station?
Thank you for raising this—what you described reflects exactly the kind of challenges we’re working hard to solve right now.
Improving Yarbo’s autonomy is our top software priority. We’ve dedicated significant resources to refining rear camera recognition, path precision, and error handling. These aren’t small fixes—but we’re making steady progress.
You can expect a major update during this mowing season aimed at delivering a much more stable and intelligent experience. Each firmware release continues to bring meaningful improvements, and that pace won’t slow down.
We’re committed to getting this right.
Hi,
Does the back brace/trimmer kit come with a different battery cover? I thought I heard that in the video but I do not see that on the website description?
What is the weight of the back brace? On the live feed they said the trimmer is about 35lbs?
Can you allow data centers to be named as you do cores in the app please? It would be easier to identify which data center goes to the correct core. When you open one core in the app and select data center, all of your data centers appear. But only one is linked to one core.
Best Regards,
Matt
Thanks for your reply. My order number is Order 2069. I would love to get a spare deck as a backup as I use the mower 3-4 times a week during this time of year and would love to minimize the down time. I just signed up to be a Yarbo ambassador in this area to help other users work out the issues that come up. I am an engineer with over 30 yrs of experience bringing consumer electronics products to market. So I fully understand the challenges and look forward to help you work of the kinks of this great product.
Can you address the power supply issues that are causing failures in the Yarbo core? I just got a local Tech College to purchase one, [it arrived last week], and the power supply is not updated, but I have seen online people are getting units with the power supply in a new location.
Thank you Allen! My Invoice # is 40113. BTW, look forward to the delivery of edger and grandular spreader this summer. These accessories should be game changers in automating lawn care. I appreciate your focus on maintaining a ready supply of needed replacement parts.
Thanks for the valuable information. I am backer #173. The 2023 model gave me so many issues it wasn’t useable. I’m happy to report that upgrading to the 2024 model was what I needed and am getting some good use of mowing presently. The parts issue is #1 for me and hopefully I’ll see my parts arrive soon. Customer service has been great and have usually responded within 24 hours. Looking forward to the trimmer, spreader and sprayer. The only issues I have with mowing seems to be navigating slopes, mostly while turning. Maybe a software feature that recognizes the slope and corrects the mowing path to only go perpendicular to the slope? I think the product is mostly to the point where I feel confident in recommending it to others.
Hi,
I see you have stated the mower module and snow blower modules are receiving updates, upgraded mower deck, revised blades etc, better machined gears etc.
Will any of this be transferrable to current m1 module? Will there be an upgrade kit we can purchase an install? Same with s1 update, can we purchase an upgrade kit when these updates come out?
Best Regards,
Matt
Are you okay with the marketing/advertising going far beyond the current state/truth of the robot’s capabilities? I think trust with current and potential customers is extremely important for newer companies, and I think this type of marketing greatly diminishes that trust. You have such a cool and groundbreaking product that I don’t see the need to stretch or hide the truth.
Hi Allen, just a comment. There’s been a massive night and day difference from when I first powered on my Yarbo in December. Huge in terms of capability and stability, at least for me. The upcoming Tow Mode with “Go To Waypoint” is going to be a big step, looking forward to it. Tons of people are waiting on that, I think. Thanks for the continued improvements.
Hi Allen,
Thank you and your team for all the hard work making a great product with a lot of potential. It is already saving me so much time and effort around the yard! I know you guys are working very long hours trying to solve many complex problems right now. I was wondering why the current design has so many screws. It seems like on the parts that are designed to be removed a lot that this could actually become a problem over time. For example the low and high mount RTK antenna mount swapping between seasons. Won’t this wear out those components quicker vs something that was more quick attach?
Can we see some redesigned accessories that could be sold to address some of these as an upgrade option for existing owners? As an example, I would love to see a redesigned module cover for the S1. One that doesn’t require a tool. Thumb screws or some type of quick release would be ideal. Finding a tiny screw in the snow when you drop it is impossible. I would love to see a move towards a tool less design. Don’t get me wrong, I love the fact that you guys include the tools with everything. It’s a great touch along with a world class unboxing experience.
Thanks for taking the time to do this. It means a lot. And please thank the team for all the hard work.
Hi Ethan and Rachel!
Hi,
Thank you for the detailed message—and I sincerely apologize for the conflicting information you’ve received. You’re absolutely right that consistency in support communication is critical, and we’ll be taking steps to align our team internally so this doesn’t happen again.
To clarify: while it is technically possible to share one Data Center (DC) across multiple Yarbo units, it’s not the recommended setup for most users due to key limitations.
Here’s why:
  • HaLow Connection is 1-to-1: Only one Yarbo can use HaLow with a shared DC. Any additional units must rely on Wi-Fi or 4G for communication.
  • RTK Stability Risks: Sharing RTK correction data over a local network can lead to reduced accuracy or signal interference.
  • Network Sensitivity: If the DC loses internet—even briefly—it can interrupt RTK corrections for all units connected, especially in shared setups.
For these reasons, the most stable and reliable setup is to have one Yarbo paired with one DC, both on the same local network. You don’t need to place them on separate routers or VLANs unless you’re attempting a highly customized configuration.
That said, we do support advanced setups in specific cases. If you’re comfortable with the trade-offs and want to proceed with a shared DC, our team can walk you through the custom pairing process step by step.
Thank you again for raising this—it’s a thoughtful question, and your feedback helps us improve not just the product, but the experience around it.
Good point about the small screws & cold weather. :slight_smile:
I have the same problems dealing with those little screws. It is a serious challenge to handle small screws in the snow and bitter cold weather. A dropped screw will disappear into the snow and cannot be found. A quick release type of design would be preferable to any screws.
