Combine Adjacent Mowing Areas into a Single Mowing Pattern
Currently, when multiple mowing areas are selected, Yarbo mows each area separately in sequence. I would love to see an option where adjacent or touching mowing areas are temporarily treated as a single large area for that mowing session.
This would provide a cleaner and more professional-looking cut because the mowing pattern could continue seamlessly across area boundaries instead of restarting in each zone. It should also improve efficiency by reducing unnecessary turns and transitions between areas, resulting in faster overall mowing times.
Ideally, this could be an optional setting that users can enable when selecting multiple areas to mow.
This was brought up a few times before and I think it would be nice to group path planned lines across multiple areas. At a minimum, let the user adjust in real time the path lines directions so that it can be manually lined up easily across multiple areas.
Thanks for sharing your suggestion! While this feature isn’t currently among our top priorities, I appreciate you taking the time to share your feedback. I’ll continue to monitor community interest and make sure your suggestion is passed along to the product team. Thanks for your understanding!
