Enable "Fan Mode" for Continuous Use of Blower Module During Charging
Summary
Introduce a “Fan Mode” that allows the Yarbo blower module to operate continuously while the device is plugged in and charging, specifically for use as a high-powered cooling fan in garage or outdoor workspaces.
User Need
As a user, I want to repurpose the blower module as a cooling fan while working outdoors or in a garage. The module already outputs a strong CFM and would function well as a personal fan, but its current behavior limits usability for this purpose.
Current Limitations
  • The blower turns off immediately if the user navigates away from the Yarbo app, making background use impossible.
  • The blower cannot run while Yarbo is plugged in and charging due to built-in safety restrictions.
  • Battery drain is high during blower operation, reducing usability for extended periods.
Proposed Solution
Implement a “Fan Mode” that:
  1. Overrides auto shut-off when switching away from the Yarbo app.
  2. Allows blower operation while plugged in and charging, bypassing current safety restrictions when Fan Mode is explicitly enabled by the user.
  3. Optionally limits RPM or adds timeouts for safety/thermal control, if necessary.
Benefits
  • Enables users to repurpose their Yarbo blower for new use cases (e.g., personal cooling fan).
  • Increases year-round utility of the device.
  • Reduces frustration around abrupt blower shutoff during multitasking or power constraints.
Optional Enhancements
  • Add a dedicated “Fan Mode” toggle in the app settings.
  • Add a runtime timer or auto-off feature for safety if left unattended.
Thank you for your innovative suggestion—we really appreciate the time and thought you put into this idea. While it’s a creative and practical new use case for the blower module, I’m afraid that due to limited development resources, we won’t be able to consider implementing this feature in the short term. That said, your feedback has given us a valuable new perspective, and we truly appreciate you sharing it with us!
