[2024] Perform Routine Maintenance
How to Perform Routine Maintenance of Your Yarbo Snow Blower
Keeping your Yarbo Snow Blower in good shape is easy with a little regular maintenance. Here’s a quick guide to make sure it’s always ready for action when winter rolls in!
1. Stay Safe First
Before you dive into any maintenance, keep these safety tips in mind:
:warning: Important Safety Tips:
  • Wear “closed-toe shoes”—no flip-flops or barefoot maintenance.
  • Put on some gloves and goggles (safety first!).
  • Always turn off Yarbo and disconnect the battery before doing anything.
2. How to Disconnect the Battery
Follow these steps to safely disconnect the battery:
  1. Shut down Yarbo in the app.
  2. Double-check that all lights are off.
  3. Unscrew the anti-theft bolts on the battery cover.
  4. Unplug the cable and remove the battery pack—store it somewhere safe.
3. Cleaning Your Yarbo Core
Keep Yarbo clean to prevent issues with performance. Here’s how:
  1. Use a soft cloth or brush to remove dirt and debris.
  2. Skip the solvents or large amounts of water—they can damage Yarbo’s parts.
  3. No high-pressure water hoses—gentle is better.
4. Quick Maintenance Checklist
  • Battery Check: Look for any signs of wear or damage.
  • Tighten Bolts: Make sure everything is securely fastened.
  • Camera Check: Wipe the lenses to keep obstacle detection working smoothly.
  • Clear Debris: Keep tracks and other parts free of snow or dirt.
5. Bonus Tips to Keep Yarbo Running Like a Pro
  • Store it properly when not in use to avoid wear and tear.
  • Charge the battery regularly during the off-season to keep it healthy.
  • Do a quick system check before winter to make sure everything’s ready to go.
With just a little care, your Yarbo Snow Blower will be ready to handle anything winter throws at it. Regular cleaning and basic maintenance go a long way to keeping it in top condition. If you need help, Yarbo Support is always here for you!
