The adjustments do not work. I have set the pathway offset to -0.1-+0.1 meters. so 10 cm offset max. why is the offset so closer to 50 cm.
Hi there, we have not received similar feedback before, so this may require further investigation from our support team.
Could you please observe Yarbo’s actual offset distance during the next run? If the issue still occurs, feel free to submit a support ticket so our team can investigate further.
