pathway tips to reduce turf wear?
Does anyone have any suggestions for creating pathways to keep the mower from always cutting across the same choke points? I tried creating one around the corner of my house, but Squealer (as my wife calls it) kept cutting the corner and sometimes took the path in reverse and then cut the corner, causing even more wear. This screenshot shows the end of a flower bed where Squealer traverses many times during a long plan. How can I get it to move back?
if you mow frequently, you could drop a NGZ there (and various other places) and enable and disable them to vary the pivot points. You could use some dead ends to cut the NGZ’s that you enable or just let it get cut on a subsequent mow.
Unfortunately, not too much else you can do that I am aware of. This is something they are working on. I think they said not this update coming up but possibly the next one.
Thanks, that should work
