Is there a way that you make the reverse auger mode permanent? Would like to remove the auger for the summer and replace it with a drum sweeper bristle brush, so that I can use it as a sweeper while utilizing the same programs from the snowblower except for the reverse auger rotation.
Thanks for sharing your idea and use case with us. It’s definitely an interesting concept to repurpose the snowblower setup for sweeping applications.
At the moment, we may not be considering this feature, but we truly appreciate you bringing the suggestion forward and sharing your thoughts with us.
