Power Reserve “Sleep Mode”
If unit stalls (such as frequently while awaiting GPS recovery) requiring intervention, automatically initiate a “sleep” power reserve mode at 20%, along with an audible PUSH notification AND text prompting intervention to prevent full battery drain from occurring.
It is indeed hard to get back to the pad when the battery is dead.
At least with the extra charging cord you only have to carry the battery.
Please explain Ken. My wired charger (circular 2-prong connector) is not compatible with my battery (pyramidal multi-prong receiver plug.).
I’ve only been able to connect my wired charger to the Core via the rear outlet, not directly to the battery.
Do you have a different setup? How are you able to remove and charge the battery (only)?
Thanks
Click on the yellow words in his reply it will send you store to the cord to purchase it. @Turk
Turk,
I love the idea of an automatic shutdown to leave some battery power in reserve with push notifications sent prior to the shutdown. However, I suggest the Yarbo automatically hybernate (shutdown) at say either 10% or 15%, if for some reason the Yarbo has not returned to its pad because the Yarbo already returns to the pad when the battery has discharged to 20%.
Then, should you have to go on a rescue mission, the Yarbo would need to be restarted with the power button, and then there would be enough battery power at the 10% or 15% level for you to manually move the Yarbo as appropriate. Wheel barrel not required. :slight_smile:
Best regards,
Alvin
I would suggest it be configurable. I personally would want it to auto shutdown at 5%.
Bryan…I like it! Configurable is even better.
Alvin
Thanks for the useful suggestion. I’ve also reviewed all the ideas shared in this thread and summarized them as a feature request for our team to consider internally.
That said, this particular feature is unlikely to be developed in the short term, as it’s currently a lower priority compared with other ongoing items.
We really appreciate you taking the time to think this through and share it with us.
has anyone played with the scheduled no-charge setting in winter? It appears to allow the battery to go below freezing. Testing if it’ll kick back on eventually or just draw a bunch of power tomorrow morning when the schedule ends. If this works correctly we could have adjustable schedules for “charging” and workplans to optimize power usage
How’d it go? Did it draw a bunch of power when the schedule ended?
Yeah, it was keeping the battery warm so not really feasible ATM, we’ll need a deeper integration for it to be useful in winter.
Edit: Maybe if we got official HomeAssistant integration we could feed in a local outdoor temp/accurate future temp forecast and it could skip or do heating just before a scheduled run. The batteries do self heat as you use them, you do get noticeable loss of power output if they’re reallly cold but you just “slow down” a bit until they warm up.
Turk and Yarbo,
The app now has a “Low Battery Auto Shutoff” toggle under Work Preferences that automatically powers off if the battery stays below 5%. After restarting, the rover will stay on so that it can be moved.
The feature worked great for me, allowing me to make a powered rescue :slight_smile:
Thanks for the idea Turk and Yarbo for implementing it.
Best regards,
Alvin
