Overnight My Yarbo stopped and returned to pad after detecting rain. I hit resume the next morning. It mowed the area scheduled for the morning instead of finishing the area it stopped due to rain. Is there a way to get it to finish the area it had started before continuing with other areas? I guess I could have paused area scheduled for the morning. But this would have made it restart the partially completed area.
That’s interesting, if you manually hit resume it should’ve still been paused for the previous plan and not queued for the new one. You may want to submit a support request so they can document that.
To complete the previously started plan, take a look at your work history and there should be a percentage completed. Start that area again and use the slider to set the percentage to about 1% before the completed percentage and it should pick up near where it left off with some overlap.
Hi there, under normal behavior Yarbo should resume from where it left off previously after the task was interrupted by rain.
If you continue experiencing the same issue where it starts a different scheduled area instead, please feel free to submit a support ticket. Our support team can then further investigate the logs and look into what may have caused this behavior.
