Hi there, please try Bryan’s suggestion and see if it helps resolve the issue.
If the issue still persists, please update your support ticket and provide the requested information from our latest reply. Our support team will continue investigating the issue and provide further assistance.
Created new plans with a unique name (adding 07-26 as a suffix).
Update the schedules to use the new plans
Deleted the old plans
Restarted the app
The old plans are back
Restarted the app
Old plans are back (yes, tried twice)
As for the ticket
That requested information was
The exact time zone, date, and time when the issue occurred
Screenshots of any error messages in the app and photos of the scene at the time of the issue
The date/times are in the attached image. Timezone as previously mentioned is Central US.
There is no error message. I’m not sure what photo the support team would be looking for. The lawn mower is back on it’s charging pad.
I would expect these types of issues from a BETA product, but this has been generally available for over a year, and given the price point I expect better.
Hi there, based on the screenshots you provided, it looks like the manually started work plan completed normally, while the scheduled tasks are the ones experiencing the issue. Is that correct?
Could you please check your schedule settings and see whether the “Next Run Behavior” is set to “Resume Next Time”? If so, please try changing it to “Start Over Next Time” and test again. This setting could potentially be related to the behavior you are seeing and may help resolve the issue.
If the issue continues after this adjustment, our support team will continue to follow up and help investigate further.
Got an alert today: “Plan Paused - Failed to read plan. Please delete it and create a new plan. (WP004)”
Investigated and found:
2 out of 3 schedules had no plan attached
About half of my plans had disappeared entirely
Workaround: I recreated the missing plans and reassigned them to the affected schedules.
Has anyone else seen plans silently disappearing like this? Would be good to understand what’s causing it before it happens again — losing plans without warning is a bit concerning from a reliability standpoint.
If you delete elements associated with those plans, like a memory path for example, it deletes the whole work plan. A quirky design, but probably makes sense to the devs for some back end reasons.
It is very annoying, bad enough when you get start and completed of a 4 hour job in a half an our. Worse when it doesn’t notify you and you check the run jobs for the day later and find it.
