Scheduling Problem
I had to move the location of the base charging station due to the battery overheating issue. I had 6 areas set up and a schedule set for each area. It was working as it should with the paths to each area.
After I moved the charging base I created all new PATH’s to the different areas. Deleted all the old Pathways prior to creating the new pathways.
I sat up the docking station at its new location and got a CONGRATS for successfully setting up the docking station.
So EVERYTHING is set up JUST LIKE it was prior to moving the docking station to a cooler location.
HOWEVER, none of the schedules will start on their own. I have to manually go into the scheduling part of the App and actually have to hit “START” for the mower to start mowing the area. When it is finished with the job it just stops right there and does not return to the charging station. I have to manually drive it back to the charging dock.
Any idea of what is happening?
Pathways to the charging station, schedules, and work plans all will be deleted when you reinstall the docking station. You just need to recreate the work plans and then set schedules again to them. Also, you don’t need to have pathways from the dock to each area. You can chain areas together with pathways and the Yarbo will navigate it’s way to each area through the others.
