What are current best practices around running multiple Yarbo’s on the same site for mowing?
Backing up, the goals are:
reduce wear/tear on a single Yarbo for a large property (spread the workload)
have a backup ready to go in case one yarbo breaks down (have had this occur twice now with no backup solution)
ideally minimize duplicate components and share components - 1 data center (stricter requirement as mounting it is a PITA), 1 property map (I’m not mapping everything again), 1 charging pad (less of a requirement)
I am open to entirely different solutions for these goals.
With NetRTK, you can share a DC. You cannot do this (reliably) using DC positioning. DC 2.0 when released will support multiple simultaneously (or it is supposed to).
Hi there, as our experienced community members mentioned, one possible setup is to use NetRTK for positioning on both Yarbo units. This allows each Yarbo to obtain positioning independently without requiring both units to rely on the same Data Center for positioning.
You can create the property map with one Yarbo, upload the map to the cloud, and then download the same map to the second Yarbo when needed. After downloading the cloud map, please perform a Map Drift Correction if necessary to fine-tune the positioning accuracy.
If you plan to use the two Yarbo units one at a time, this setup can help you share the same map and use a single docking station. For the Yarbo that is not currently in use, you can use the wired charger to keep it powered and ready.
Hope this helps provide a more flexible way to manage multiple Yarbo units on the same property.
