Planning for the future, following the success with my Yarbo, I will to need purchase another three to cover our lawns and keeping the driveway clear, replacing our Husqvarna, Neowmow and Mammotion mowers.
Some questions:
- Can multiple Yarbos work from one Data Centre?
- Can a Yarbo share its charging dock?
- Is the battery ‘paired’ to a Yarbo or can they be swapped between cores?
- Can a charging dock be allocated to a cutting area and different Yarbos assigned to the same cutting area, scheduled at different times, and use the appropriate charge dock?
- Can maps be shared between Yarbos or is the map unique to the core it was mapped with?
Thank you.
Ash
It is possible but there are trade offs. It works best currently to use one DC per core.
The docks are not unique to the rover but sharing them is problematic because the cores are unaware of each other.
They are not paired and can be swapped.
You can have multiple docks but currently only one can be active at a time per work area. It’s best if each rover has its own dock to avoid collisions.
Maps are unique to each core. It’s possible for support to copy maps from one to another but this is generally not recommended and a bit of a process to do so.
A fleet mode is something they’re working towards so one day I believe these things will be possible.
Hello. I’m soon going to have two Yarbos on the property. The one we already have is working well with maps, schedules, charging dock, etc.
Has there been any news regarding running multiple Yarbos on the same antenna and sharing maps during the recent months?
Don’t recommend sharing a DC but you can copy the maps following this guide. They won’t share, just a copy.
As Bryan mentioned earlier, we don’t recommend having two Yarbo units share the same Data Center, as this may affect stable and smooth operation.
