Start point opposite end in area to entry Pathway!
Why is the Routing algorithm choosing the furthest point to start from the entry/exit path? Is there a way to mitigate this? It’s wasting time just to get to the top.
Is this where you started mapping? That’s usually where it will create a start point. It’s definitely inefficient in its current iteration and cannot be user set, yet. Have you tried the adaptive pattern on this area? Might help.
At the moment, the starting point is automatically calculated by the system and can’t be manually adjusted. You can try changing the route pattern in the area settings to Adaptive Route and see if that helps improve the behavior.
