Controlling mowing start point
Does anyone know if there is a way to control the initial starting point for mowing? Mine decides to start at the last map point before I completed the perimeter automatically when mapping. The problem is this point is far from the dock station, along a fence line on a 40 degree slope area along that fence? It goes down the hill then tries to maneuver around but gets stuck against the fence because when turning around it violates the perimeter even with a 4” setback.
Also what are people’s experience/expectation with accuracy? i am surprised at how much deviation (3-4”) seems to occur along a mowing path at the perimeter(and yes these are in areas with excellent gps/data center signal). Having to use setbacks to avoid violating a perimeter/no go zone seems disappointing. I come from Ag where we use rtk for tractor auto steer and expect cm equipment accuracy.
I am also interested in this topic as well. My issue is the yarbo follows same exact path each time going between areas and the charger which has created dead grass. Curious is they have an adjustment for this as well.
See: Set starting point manually - #6 by Yarbo-Forum (that’s Yarbo’s response, but you can scroll up to see the whole discussion)
Thank you for your thoughtful feedback.
At this time, customizing the initial starting point for mowing is not supported. That said, we’ve added this feature to our request list for future consideration. Since it may require significant changes to the current route algorithm, it will need careful evaluation and could take some time before moving forward.
Regarding accuracy, Yarbo is designed to achieve centimeter-level precision. However, certain factors—such as slopes, terrain complexity, or temporary signal variations—can affect performance. To help us investigate further, we’d appreciate it if you could submit a support ticket with more details about your setup.
We truly value your input—it helps us continue improving the Yarbo experience.
