Yarbo stuck in one spot, at start of a work plan area
I mapped a new area, went to cut the grass in new area, yarbo drove in area and then just moved back and forth, a spun in circles. I tried turning to bump avoidance, no go, changed to custom and turned off vision. No go. Powered down Yarbo, no go. I did a record issue in app, not sure what that does. I finally gave up, sent him to a different area. He is working ok there. Cut 2 areas earlier today also.
Look on your map and see if you have some spots where you backed up. Will be like a weird hook. Edit the map and remove that section. Also, If you changed the boundary set back to zero, put it back to 4 that may also work.
No backups, I have all my maps set to zero, no other issues. I deleted the map, and re mapped it, issue is gone. Odd but man it makes a person mad. A lot of time wasted trying different setting and then having to remap. But when Yarbo works he works good.
Response from tech support…
We want to assure you that the issue you’ve reported is a known issue and our R&D team is actively working on resolving these problems. A thorough investigation is already underway, and targeted improvements are being implemented to address the problem
We are committed to releasing software updates in the coming days that will include fixes and optimizations for this specific issue. Once released, your device will be able to receive the update automatically, provided it is connected to the network.
I’ve had this issue for about a week with an open ticket, promised to be elevated to the next level. I followed up daily and while customer service is friendly, they have no idea what is going on but do say this issue is not isolated to my unit. Also, my steering controls are out of order.
Yarbo is worthless right now.
Have you tried this? Yarbo stuck in one spot, at start of a work plan area - #2 by bryan.wheeler
We’re truly sorry for the delayed response. I’ve contacted the support team to escalate your ticket as soon as possible and will continue to follow up on it personally. We sincerely appreciate your patience and understanding.
I have had the same issue in one area. If you pause the plan and “restore default settings” before restarting the plan mine will begin. Once the plan is running, you can pause it and edit most of the settings back to what you want…some options are unavailable.
This is most likely because you have an area that is pinched or the boundary overlaps on itself causing a path planning issue when the boundary set back is set to zero. Setting the set back to 4 usually fixes the glitch. Remapping or editing the map where the overlap or tight NGZ and boundary is will also help.
