Yet Another Auger Height Questions
Had my first run today, definetely needs alot of adjustments. My second run was better. This is with cars on the halfway of my driveway as no go zones. Now, for Auger height…my driveway definitely is not flat actuall on a slight slope, due to that slabs have a few cenimeter drops. I do also have issues with my blower when I go thru those..so my question..does she dynamically adjust height if she gets to those points? Or is it safer to adjust the height based on the clearance during the mapping?
if it detects it is stuck, it will back up, try again, adjust height as needed and continue on and then go back to the set height. If they are high spots, this can be a problem if there’s a lot, otherwise low spots you’ll probably be ok.
Thanks for sharing your experience — it’s great to hear that the second run already showed improvement after some adjustments.
As Bryan mentioned, Yarbo will dynamically adjust the auger height when it detects slopes or uneven areas.
That said, for driveways with noticeable slab drops or uneven sections, it’s still a good idea to set an appropriate base height during mapping to help minimize potential issues.
Let us know if you have any other questions — we’re happy to help!
