2024 Blower with hose attached
There are no suggestions on how to navigate the Yarbo with the Blower module attached to
the core and the hose extension attached to the Blower.
While holding the extension hose, attached to the leaf blower, your hands are fully occupied.
Navigating using the app or the remote control is a exercise in juggling to say the least. Also,
with the hose attached to the blower, there is no practical way to map an area. If possible, a
solution could be to activate the follow me mode for the leaf blower module. This would allow
the user to guide the Yarbo from area to area while using the hose attachment to remove debris
from landscaping.
This is something that I believe they’ve stated they intend to implement at some point. In the interim, I would disconnect the hose while maneuvering the rover with the app or controller and then reconnect it once you get it to where you want to work.
Thank you for sharing your experience and suggestion! We are currently in the development process of adding the “Follow Me” mode to the blower module. If everything goes smoothly, we expect to include this feature in future updates. We appreciate your feedback and will keep you updated. Thanks again!
Release 7? Is that 3.8.7?
@bryan.wheeler Thanks. I was going to ask for a decoder ring.
Apologies for the confusion earlier! To clarify, we haven’t finalized the version number yet. When we mention “Release 7,” we’re referring to an update that’s expected to be available by the end of April (if everything goes smoothly) or in May. Thank you for your understanding!
