[2024] How does Yarbo deal with wet snow?
The plow blade is designed for handling wet snow, which tends to be heavier and more challenging to clear. Wet snow typically forms when the temperature rises to around -5°C, causing some snow to melt and become sticky.
After attaching the plow blade, Yarbo can effectively “push” snow out of your working area. For optimal snow removal, set the auger height as low as possible.
Using the Snow Blower in Wet Snow:
While snow chunks may stick to the snow blower at times, it can still clear your yard effectively. For the best performance, set the movement speed to “medium” (in the app under Settings → Work Preference).
